i need a pic of a WOT switch, pissin me off
Old Dec 12, 2002 | 04:29 PM
Hawk's Avatar
i can't find a way to mount it that looks good, does anyone have a pic?? thanks
Old Dec 12, 2002 | 08:12 PM
Loadre's Avatar
In my sig there's a pic. Many ways to mount it, though.
Old Dec 12, 2002 | 09:10 PM
RacinLT1's Avatar
Loadre,thats a bum link FYI.....cant find page
Old Dec 12, 2002 | 09:36 PM
Hawk's Avatar
i figured it out so it looks clean. I put it on the plastic cover on the inside, i'll get pics. Lata
Old Dec 13, 2002 | 01:27 AM
MBonZ28's Avatar
I wish i had pics of mine to share. i am real proud of ot. I had it sticking up like most people do and I couldnt bare it. I will do my best to describe how I installed it.
Its placed up against the intake between the intake and throttle lever behind the TB. I actually had to grind a little off the inside of the lever for it to work. the switch faces forward with the connections up. I also had to bend the tabs (very carefully) the other way. and i ran the wires behind the switch. the part that hits the switch to activate is a piece on the throttle arm that I believe acts as a stop when the TB is closed. The bracket connectors to the bracket that supports the throttle cables.
it was kinda tricky to do this but worked out real well. take your time and be creative. I hope this helps
Old Dec 13, 2002 | 03:02 PM
JD30thZ28's Avatar
Thumbs up
There is a pic of mine below however it seems as if I may be moving it again I will post pics of any changes I make
WOT Switch
Old Dec 13, 2002 | 03:45 PM
gb95zconv's Avatar
I mounted mine to the floorboard under the accelerator pedal....doesnt matter how it looks there because its out of sight.
Old Dec 14, 2002 | 11:04 AM
Loadre's Avatar
Link in sig is fixed now. Had a damn "/" on the end of it so it wouldn't work You prolly don't care though since you're already done
Old Jan 2, 2003 | 10:47 AM
Zippity'Z's Avatar
Hey there- if you are still looking for the WOT switch- here is a pic of one. I know someone that makes these as well as ones for other motors so let me know if you want something that is bolt on instead of worrying with bending the generic piece of metal.
*R*
Old Jan 2, 2003 | 10:49 AM
Zippity'Z's Avatar
Whoops
Fastbird93
Apr 9, 2016 07:01 PM
willismoons
May 27, 2015 04:03 PM
Jlo
Feb 3, 2015 09:41 PM
taner
Aug 14, 2002 10:10 PM
