Hows this for a n20 cam
Old Oct 29, 2003 | 01:36 PM
dnz28's Avatar
specs- 242-248 lift .540-.562 lsa112 any comments would be great.
Old Oct 29, 2003 | 03:04 PM
Rival's Avatar
on 112 lsa your going to be blowing out the juice on the exhaust side. 114 would work better on the bottle. The 224/236 on 114 would work well with a power adder. I think there is now a cam the next step bigger. A 242-248 is a pretty big cam, what motor is it going into? What are your goals? How big of a shot of n20? Please give some more info on your setup.
Old Oct 29, 2003 | 04:02 PM
dnz28's Avatar
It going into a complete forged 357 with stage 3 heads, 13.2 to 1 compression ratio. I want to run a mininum of a 175. I am plaining on a two stage system first stage 150 second stage another 150. this is a track only car so it ***** to wall on everything.
Old Oct 29, 2003 | 08:09 PM
Josh-'04 GTO's Avatar
Your cam choice is fine. Nitrous doesn't have the same pressurization effect on the intake tract as a blower, so the 112 LSA should work with no problems. I assume you're gonna spin some RPMS given that size cam in a 357.
Lions3
Aug 30, 2002 01:03 PM
CamaroZBoy
Aug 19, 2002 12:41 PM
CLEAR
Aug 16, 2002 02:35 AM
LumpyCamZ28
Aug 13, 2002 09:16 AM
CeeBee94Z
Jul 31, 2002 02:20 PM
