Hows this for a n20 cam
on 112 lsa your going to be blowing out the juice on the exhaust side. 114 would work better on the bottle. The 224/236 on 114 would work well with a power adder. I think there is now a cam the next step bigger. A 242-248 is a pretty big cam, what motor is it going into? What are your goals? How big of a shot of n20? Please give some more info on your setup.
It going into a complete forged 357 with stage 3 heads, 13.2 to 1 compression ratio. I want to run a mininum of a 175. I am plaining on a two stage system first stage 150 second stage another 150.
this is a track only car so it ***** to wall on everything.
Your cam choice is fine. Nitrous doesn't have the same pressurization effect on the intake tract as a blower, so the 112 LSA should work with no problems. I assume you're gonna spin some RPMS given that size cam in a 357.
