how much nitrous on a 396
we are still in the process of building it up. the numbers we have run though will be in the 500 mark in high alt. at the rear wheels. That should be somewhere around 600 mark at the flywheel. This is on a BUILT motor. there is about 12 going into just the motor, no to mention the ignition, the nitrous, the nitrous controller, the rear end, the clutch/flywheel, the new exhaust and a few other things. find out what your cam is and i could give you a better idea of whether or not your numbers are realistic.
i was looking at like 660 rw and people here jumped all over me. This was long before i ran the numbers and saw what was possible. while most were in straight denial, there were a few that knew what they were talking about. while i agree there is LONG road for 660 out of an LT1, and its not possible without race fuel, they were closed to a lot of the ideas. 500 is a hard number to hit at the wheels N/A. It can be done, but its not an everyday car.
I don't believe JE makes Hyperueutiectcici piston's.. Did i spell that right?
but i believe the reason why he shouldn't spray above a 150 shot is most likely due to the compression height of the piston in a 396 with what i'm guessing is a 6" rod.. The top of the piston is too thin to run a bigger shot safely.. Not saying it can't be done though.. but carefully.. Mine has a 5.85 Rod therefore having a bigger compression height i.e more material to take the heat... Just my .02 take other's advice get a dedicated fuel system and run some high octane to help avoid the detonation which will turn you motor into a boat anchor.. Good Luck..
Hypereutectic pistons are actually stronger than forged pistons are because of the silica added. But because of that they are more brittle.
As long as you don't run lean, Hypers are fine for nitrous use.
And also, whether your rotating assembly is forged or not, if your rings aren't gapped for big shots of nitrous, don't hit the motor with a big shot of nitrous. because forged or not, if your ring ends butt..... its all over.
Originally posted by SROKED30TH
Scottland174: What do you mean by the rings not being gapped correctly ? I've never heard of this being a problem before, please explain some.
Rich Krause
From: Albuquerque,NM--5,600 feet above you sea-level cats
I was putting a 250 shot on 355,until it dropped a valve,and broke 6 springs.kinda nervous about that much on mine.You should be okwith a 150 or 200 shot.I have done 150 now with no problems(the last time i said no problems it blew up).
RUENUF
Mar 13, 2016 03:37 PM
