how much juice can a bolt on lt-1 take
Old Dec 4, 2005 | 02:35 PM
1quickgt's Avatar
i ahve a 94 trans am gt with mild bolt ons, i was thinking of going with a wet 100 shot? will that be ok for a stock internal lt-1? and will i need to retard the timing or redo my fuel system? any help/advice would be VERY apprecated...also whats the diff between wet and dry kit?
Old Dec 4, 2005 | 03:53 PM
Cmr0z28's Avatar
Re: how much juice can a bolt on lt-1 take
It will take a 100 shot all day long. A lot of people run 150 shots with no problems too. You shouldn't need to retard timing with a 100 shot on the stock tune, but I retard timing 1 degree for every 50hp because I have an aftermarket PCM tune. Upgrading the fuel pump would be a good idea, as well as a window switch.
Old Dec 4, 2005 | 03:56 PM
1quickgt's Avatar
what would you sujust a wet or dry kit
Old Dec 4, 2005 | 04:04 PM
Cmr0z28's Avatar
Wet....NX
Difference is, wet kits have a fuel solenoid and spray the correct nitrous/fuel mixture into the engine based on jet sizes. With a dry kit, it only sprays nitrous into the engine, and the PCM needs to compensate and add fuel via the injectors. Stock injectors + dry kit = not a very good combo.
Old Dec 5, 2005 | 01:32 AM
1quickgt's Avatar
awosme you have been more then a help man thanks very much
Old Dec 5, 2005 | 01:42 AM
Cmr0z28's Avatar
no problem
Noenav
Mar 1, 2019 07:38 AM
Sergio
Jan 27, 2016 04:27 PM
maybe2fast
Mar 16, 2015 09:45 AM
alex5366
Feb 17, 2015 09:07 AM
sskevinm
Dec 18, 2014 11:16 AM
