How Much
Old Nov 15, 2007 | 09:20 AM
  #16
Ray@NitroDaves's Avatar
Originally Posted by Bandit 1
I think you could get away with a 75shot and pull no*, arn't most kits sold are kinda dummy tuned, a little on the rich (safe) side.
If you have to much timing you can have issues even if the A/F is rich....all the different factors are important when running nitrous.
1) Spark plug heat range
2) Timing
3) Octane
4) Air fuel ratio
Old Nov 16, 2007 | 12:44 PM
  #17
SNOTGREEN's Avatar
Not to hijack, this thread is very helpful to beginners w/spray on LT1's. I intend to do similar on a '93. Will the MSD 6-series boxes do the job as effectively as the Mallory, or is that just preference. Thanks.
Old Nov 16, 2007 | 01:02 PM
  #18
HardcoreRM125's Avatar
MSD 6's just retard the timing. No built in window switch, functions for two-step, etc. If you already have one, its cheaper to buy their window switch and wire it in with it. But if not, the Mallory is a better buy. One problem seems to be longevity with the Mallory's but I only use mine for on the spray. I use the bypass connector the rest of the time.
Old Nov 16, 2007 | 01:16 PM
  #19
the MSD Digital 6 does include a 2 step...the only difference is the Mallory 685 has a window switch.
Old Nov 16, 2007 | 01:18 PM
  #20
SNOTGREEN's Avatar
Yeah I get what you're saying now, and that sounds like a good idea to bypass it when not on the bottle, seems worth the $ to me. Appreciate the advice.
