How Dangerous is N20?
If I got rear ended real bad and my N20 was in the back hatch? How dangerous would this be? Would by car explode into flames? Thats probably the only thing holding me back at this point.
No, its non-flamable. The worst thing that could happen is the bottle could be knoked loose and hit you in the head...ouch.
As an oxidizer its safer than oxygen as it requires alot of heat to break it down into oxygen and nitrogen
get out of the car and run as fast as you can while yelling "NAWWSSSSS!"
.Nitrous Oxide is an oxidizer but decomposes onto Oxygen and Nitrogen @ 617'F
If you don't want the bottels to get crushed incase of rearend hit put the
(yelling) "NAWWSSSSS!"
It would be hard to crush one of them and not to easy to puncture one eather unless your getting shot at, if so then
.I think the 10 gallons gasoline in your flimsy steel fuel tank is more dangerous than 1100 psi of Nitrous Oxide in a bottel that will burst at around 3500psi and is normaly closed and some times not even in there.
Cbr02
Aug 24, 2015 07:12 AM
96z
Sep 19, 2002 10:45 PM
