hooking up nitrous switch
I have just about everything hooked up on my NX kit. I'm going to hook up my electric fuel pressure and nitrous guages to the 12v switched source from the fuse panel by the drivers door dash. Can I hook up my activation switch for the nitrous to that same source? And the bottle warmer switch, and the purge switch? Or is there another 12v switched source close by coming from the pcm?
Im no help at all. But where are you located? Im gonna need help with my NX GenX II install
If you were close i was gonna ask for help.
Good luck with it though. If you dont have it done in a week maybe ill be able to help you out.
Originally posted by silverz28
Hopefully I'll wrap it up this weekend. Thanks for the no help.
Really my post was just a good luck with the install kinda thing...
Sorry if you took it wrong.
... electric fuel pressure and nitrous guages to the 12v switched source from the fuse panel by the drivers door dash. Can I hook up my activation switch for the nitrous to that same source? And the bottle warmer switch, and the purge switch?
I have a lot of my stuff run off the "IGN" connection, and I did experience a 15A fuse failure when apparently I had too many devices activated.
That's what I needed Fred. Yes, I have the main power through a relay. Just wanted to confirm if it was ok to hook up guages and switches to the IGN on the fuse panel. Although, I don't think my purge is hooked through the relay. Just one wire to a ground and the other to the switch and the switch to a 12v ignition source. Thanks again Fred.
RUENUF
Mar 13, 2016 03:37 PM
