Hobbs Switch?
Old Jul 5, 2003 | 12:53 PM
Wild1's Avatar
Hobbs Switch?
Newbie to N2O, what is a Hobbs Switch? I can understand how it would work with a turbo or S/C but I can't figure out how to use it with N2O. Any benefit? Is it something like a window switch? Or a Fuel Pressure Safety Switch?
Old Jul 5, 2003 | 02:08 PM
slow's Avatar
the fpss is a hobbs switch.
Ryan.
Old Jul 5, 2003 | 03:29 PM
Z28ROC's Avatar
Fuel pressure safety switch. It will shut the n2o off, if the fuel pressure drops below the set psi.
Old Jul 5, 2003 | 03:44 PM
Wild1's Avatar
So is it adjustable or is it set? If I'm running a separate tank (low psi) for racing fuel (3 gallons) up front where the battery used to be, then how would I adjust the Hobbs/fpss?
Old Jul 7, 2003 | 03:55 PM
Hawk's Avatar
it's adjustable, turn the screw on top. Hook it up to a air compressor to get the psi u want.
Old Jul 7, 2003 | 06:24 PM
Wild1's Avatar
Air Compressor... great idea.
Ericksd
Jan 20, 2016 06:07 PM
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
