Help wiring window switch to Zex wet system...
Old Nov 26, 2008 | 05:18 AM
..DAMN..'s Avatar
I bought the summit window switch and i have a couple question's about how to wire it!
Heres the instructions that came with the unit.
1:Connect the black wire to a good groung.
2:Connect the red wire to a switched 12v source.
3:Connect the yellow wire to an rpm signal.Most likely the primary side of the ignition or to an rpm signal from the engine computer or ignition box.
4:The blue wire is ground above and below the set window,BUT NOT IN THE WINDOW.
5:The purple wire is ground IN THE WINDOW but not out of the selected area.
Ok i have the Zex wet system what do i connect the purple and blue ground's too? and where do i connect the yellow wire too for an rpm signal?
Car is a 95 z28.
Old Nov 26, 2008 | 06:10 PM
..DAMN..'s Avatar
Comon noone has any idea at all? Im stupid when it comes to wiring!
Old Nov 26, 2008 | 11:27 PM
Chopstix's Avatar
you will need to get a standard 4 pin automotive relay.
pin 87 will connect to the white wire on the ZEX NMU
Pin 30 will connect to the reference wire on the TPS
Pin 86 will tap into the 12v acc wire off your master arm switch
pin 85 will connect to the purple wire
wire the window switch according to the supplied instructions....you will not use the blue wire.
this is the closest diagram I all ready had...this shows the relay in conjunction with the Zex NMU
Old Nov 27, 2008 | 01:20 AM
..DAMN..'s Avatar
What does a rely do? It didnt say anything about it in the instructions.
Old Nov 27, 2008 | 03:33 PM
Chopstix's Avatar
think of the relay as a switch....the reason you have to get one, it allows the window switch to control turning the Zex NMU on and off
Most nitrous kits use one to control the solenoids...the Zex NMU has it built in. So we need to add one for the window switch to control.
Old Nov 27, 2008 | 05:50 PM
..DAMN..'s Avatar
Ok i couldnt get the window switch to work and now i know why...So i can pick up a relay at any auto store? What is the relay called? Im going to need your help wiring it!
Im soo very mechanicaly inclined but wiring gets me all confused...lol
Old Nov 28, 2008 | 12:00 PM
..DAMN..'s Avatar
Ok i picked up the window switch from Autozone like you said and wired it just how you told me. I set the nirtous to come on at 3300 and turn off at 5500 and whoo-hoo it work's thank you so very much!!
Old Nov 28, 2008 | 06:45 PM
Chopstix's Avatar
glad I could help...if you need anything else let me know.
I am usually logged in as Ray@nitrodaves so please feel free to PM or post up any questions you might have.
Keenan
Jan 19, 2023 12:24 PM
mattstrike
Mar 11, 2015 07:33 PM
warmeck
Feb 2, 2015 12:44 AM
Ryabut98
Sep 3, 2002 11:45 PM
x7x7
Aug 15, 2002 06:49 PM
