HELP: install of nx bottle opener
connect the wires and go! the directions are pretty easy. put the cap that came with the opener on the bottle so you can fully open the bottle without locing any N2O. then remove the ****, place the flat piece on the bottle, then the piece over the stud where the **** was, then the motor housing and clamp. tighten it all up and walla! the screw under the gear where it turns the valve ist he 'clutch' adjust ment, you may have to loosen it a little.
SMO Q
Feb 11, 2015 07:13 AM
Speeds8erM-1
Jul 28, 2002 06:18 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
