Heads/Cam/Spray what rpm to spray to
Old Mar 1, 2003 | 08:27 PM
TEAL94Z28's Avatar
I have heads cc306 and a nx kit. My shift points are set to 6500 rpm. What pill should I put in my window switch?
Old Mar 1, 2003 | 10:16 PM
stik6shift93's Avatar
How big are you going to spray, generally if your trans is built you can spray threw the shifts so just put a higher pill in. If it's stock and you're gonna spray big I wouldn't spray threw the shift so put something lower in ie a 6400 pill.
Old Mar 1, 2003 | 10:29 PM
TEAL94Z28's Avatar
100-150 what ever it takes to hit tens. Is it safe to spray a 100 shot at the rmp on the stock bottom end.
Jeff1904
Jun 5, 2016 05:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
damnyankee36
Sep 9, 2015 07:06 PM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
30th Anniv Z28
Aug 1, 2015 10:39 AM
