backfire
Old Feb 26, 2003 | 07:35 PM
hitman8728's Avatar
Question backfire
hey guys i was wonderign if this is bad or not i have a 94 camaro z28 a4 with not cat intake and exhust. now the problem is when i use nitrous and then i let off the gas my exhust backfires....now also when i dont use nitrous that car will back fire when i let off at high rpm. is there somethign wrong with my car?????
Old Feb 27, 2003 | 05:56 PM
stik6shift93's Avatar
This is most likely because once you turn the nitrous off it evacuates the line between the solenoid and fogger immediatly but the fuel might take a few seconds to evacuate since its at a much lower pressure making your car run rich causing the back fire. If it's only right after you spray I wouldn't worry, if it's like an hour after then I'd start to worry.
Old Feb 27, 2003 | 11:41 PM
hitman8728's Avatar
sweet thx a lot for your help that just what i wanted to know =)
Old Feb 28, 2003 | 02:05 PM
No prob, glad I could help.
Old Mar 1, 2003 | 11:41 PM
stik6shift98's Avatar
mine backfires too rembr stik93 on the highway???? and i havnt used nx it like 3 months....
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
tommalcolm
Sep 11, 2015 03:39 PM
Dzmaro
Jun 19, 2015 11:38 AM
Chet1185
May 10, 2015 09:24 AM
