having problems with bottle heater!
Old May 2, 2005 | 08:51 PM
crAzy95z28's Avatar
http://www.ls1tech.com/forums/showthread.php?t=315843
Old May 2, 2005 | 08:54 PM
markinkc69z's Avatar
Re: having problems with bottle heater!
Jumper the pressure switch to test, or just ground that terminal.
Old May 2, 2005 | 09:19 PM
crAzy95z28's Avatar
Old May 2, 2005 | 09:30 PM
the ground wire off the relay you have running to the pressure switch, bypass that directly to ground to see if the relay responds and the heater kicks on. Your pressure may be high enough already or the switch might be defective or need adjustment.
Old May 2, 2005 | 09:40 PM
crAzy95z28's Avatar
there is no ground for the relay!~
Old May 2, 2005 | 09:53 PM
huh? there has to be. I looked at your post on the other forum. The pressure switch is the ground. You better read your directions again. Term 85 is usually the ground .
Old May 2, 2005 | 09:57 PM
crAzy95z28's Avatar
i thought u mean the realy was ground...sorry bout that!
what i was going to do is just take the 2 wires off the heater and make sure it actually heats up!
Old May 2, 2005 | 10:46 PM
crAzy95z28's Avatar
fixed it...the damn adjuster screw was shut off!!
Old May 2, 2005 | 11:50 PM
I'm glad you got it fixed.
Speeds8erM-1
Aug 20, 2002 09:12 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
Speeds8erM-1
Aug 13, 2002 10:24 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
