has anyone run a 250 shot on a stock intake ?
im running the plate set up not so not sure if it will go that high but i got the pills and wanna try anybody do 250 safely on the stock intake?the car is a 96 lt1
I run that and it does fine. Make sure your lines (especially if you are running -3) are bigger than the jets you use though. I know it sounds basic but on the lines I had I had to drill the ends of the lines out a little as they were only ~.080 which would not be good if you wanted to run a .082 jet.
