H/C + TNT 75 shot. Will i be safe?
Old Dec 31, 2003 | 08:02 PM
zyoulater's Avatar
Need some info guys. See sig for mods. Will i be safe on stock injectors and stock fuel pump with just a 75 shot? I currently have 432rwhp now so i'm not sure if i will need an inline fuel pump and new injectors or not. I also plan on getting a MSD window switch and some TR6's. I bought the TNT F1 kit so is there anything else i will need to be safe. I dont plan on spraying very much only when needed I also already have a bottle warmmer and bottle blanket. Thanks for any and all info!
Old Jan 1, 2004 | 10:30 AM
wannabeZo6's Avatar
just enough to hit 500.......with that much power im suprised you dont have injectors already i have seen stock injectors at 100% duty cycle maxed at 390 wrhp.......good luck with it tho....i recomend injectors, and an msd digital 6......this way u can pull timing and rev limiter electoricly....just to be safe
Old Jan 1, 2004 | 11:39 AM
zyoulater's Avatar
I just got my car dyno tuned and i was told that my injectors were supplying enough fuel and that i did not need new injectors. I told the tuner the i would be spraying a wet 75 shot and he sadi that i would be fine. I just want to make sure i will be safe. Thanks!
Old Jan 1, 2004 | 11:50 AM
RacinLT1's Avatar
smart money would be to at least invest in a new pump. why risk starving it with a stock pump.
Old Jan 1, 2004 | 05:10 PM
DrewHMS97SS's Avatar
for a wet setup why are you thinking about injectors? to be 100% safe i would recommend a walbro fuel pump.
Old Jan 2, 2004 | 02:22 PM
XKnightRider's Avatar
75 shot no problem
I'm H&C with a 100 shot wet, no problems, at the track I go with the 150 jets, but I may add an additional in line fuel pump soon.
Mostly due to the fact that on my '97 LT1 my fuel pump went out at 30K miles!
I hope the '02 has a better pump, but I don't trust GM that much
Old Jan 2, 2004 | 04:13 PM
SVT Killer LV's Avatar
H/C and a 125 shot im all good too
Formula Steve
Sep 19, 2023 08:31 AM
AviatorDave
Dec 19, 2016 06:35 PM
Sep 18, 2015 03:46 PM
rideordie
Sep 7, 2015 08:22 AM
4586
Aug 24, 2015 11:04 PM
