Is this a good nitrous controller?
Old Feb 20, 2003 | 11:49 AM
snksknr94's Avatar
I read the thread down a bit about the NOS controllers but I was looking at getting this one. http://store.summitracing.com/partdetail.asp?part=2312 I'll be running the TNT wet kit, probably a 75-125 shot. I know some of you guys are going to say that is too small of a shot to even worry about a progressive kit, but the easier I can make this on the motor the better.
Thanks!
Old Feb 20, 2003 | 12:09 PM
mtxpert's Avatar
Well here's the skinny on a 75-125 shot:
1. You shouldn't need a progressive controller in order to hookup - spend the $200 on suspension first.
2. If you're looking at it more as a window switch/nitrous retard function - look at the Mallory 685 instead as it has all that and it's equivilant to the MSD 6A + window switch + switch activated retard + 2 stage rev limiter - $219.99 if you search on the web for Mallory 685
Specific comments on the Jacobs range from sucks to love it.....
Progressive controllers massively diminish the life of solenoids, just FYI.
Hope this helps!
Mike
P.S. If you want to see the Mallory you can check it out when I borrow the spring compressor from ya.... I'll give ya a ride in my new 175hp shot Impy!
Old Feb 20, 2003 | 01:08 PM
snksknr94's Avatar
Hope this helps!
Mike
I'll take you up on that ride!! I should be getting the compressor back next week, my buddy is doing his valve springs this weekend I believe. I dont really need it to hook up, the only thing I have left to get tractionwise, is a set of dr's. I was looking at it more as a way to not all of a sudden hit the motor with a large shot of power. Just kinda let it build up to what ever shot I run, I figured it would be easier on the motor that way.
Old Feb 20, 2003 | 06:31 PM
RacinLT1's Avatar
The jacobs controller is VERY hard to set right. the adjustments are not marked,it's a "feel" kind of setup.
Once it is set,it's good,but takes forever to get there.
Old Feb 20, 2003 | 07:02 PM
drop top steve's Avatar
I agree with Racin, I was never happy with mine, sold it and bought a Schnitz progressive unit
http://secure.cartsvr.net/catalogs/c...showprevnext=1
You might want to look at the NX controller, I've heard good things about it.
mtxpert has a point, if you set the car up right you could launch on a full shot, but if your like me and have the car set up as a daily driver and don't want to change out springs and shocks everytime you go to the drags a progressive unit helps.
Old Feb 23, 2003 | 01:53 PM
JWINN's Avatar
The Jacobs sucks!!!! And for 100 to 175 shot? No controller should be needed with that little shot. Spend some doe on some bigger rims and put a set of M/T ET streets on and fire away.
Hell, I come up on the transbreak and coming out of the hole spraying 250hp.
100,175? No need for controller! But if electronics is what you desire the Shinitz controller is the way to go. I ran there single stage model controller on my Hayabusa. It's one of the best out.
When you call down there you might get lucky and speak to Ryan Shnitz, he is one of the top guy's to beat in drag bike. But if you don't get him the girls are sharp as a tack when it come to questions.
Good Luck!
Jim
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
bandit383lt4
Dec 21, 2014 09:12 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
