Going to track for the first time with N20, couple of ?'s...
Old Nov 17, 2003 | 07:53 PM
snksknr94's Avatar
Where should I set the window switch for? Rev limiter is at 6400 rpm, shifting at 6000 rpm. Should I spray in first gear? Plus any other info would be great!
Thanks!
Aaron
Old Nov 18, 2003 | 10:41 AM
Speed Inc.'s Avatar
I do not know your exact setup so I will assume you have....
good ignition.....colder plugs,wires,digital 6 or similar(if over 100shot) to pull a little timing,and inline fuel pump (over 100shot)
I would set the ON from 3-3500 depending on your traction. This can be used to aid you a bit. I would set the OFF at 6200. I did not see if you had an A4 or not,but if you are set the OFF at 5800. The trans will survive much longer not spraying thru the shifts.
I would say the only thing thats going to make the difference of spraying in first or not is TRACTION. I would get a hang of launching with spray and see if you cn push the car and get it to hook in first gear after a few runs.
good luck
I would also throw in a little 100octane,just to be safe at the track.
Larry
DirtyDaveW
Dec 1, 2016 05:37 PM
Feffman
Oct 9, 2015 05:42 AM
Louey
Pacific
Jan 25, 2015 12:22 AM
Louey
Pacific
Dec 25, 2014 03:27 AM
