Forged pistons
Forged pistons
I have a set of SRP forged pistons in a new shortblock with only 10,000 miles on it with a hotcam, Grenalli MAF, Intake, smooth job on the heads, LT's, and TD's..
Do you think this is safe enough to run a 200 shot on or would i be pushing my luck? I know i would need to upgrade my fuel system, timing chain, colder plugs, and get a tune..anything im missing?
Re: Forged pistons
Sounds good to me. Do you have a way to pull timing for that big of a shot? Something like an MSD Digital 6 would be almost necessary. Unless you have some other sort of MSD that you can add a timing control to.
Re: Forged pistons
Not yet.. I am figuring out what i need first then in the near future i will buy the kit.. Just making sure my engine can hold.. THe 200 would only be every once in awhile..mostly 150-175'ish.
Re: Forged pistons
Whoa, I was under the impression the whole bottom end was forged. I think the crank will be okay, but I am a little concerned about the stock rod bolts. Unless you upgraded with some ARP hardware? With a good tune and everything I think she'll be okay....What kind of numbers are you making NA?
Originally Posted by WhiteLT1z
cool.. Ive heard the stock rods and crank can handle quite a bit but was just double checking..
Re: Forged pistons
youll be pressing your luck even on a 175 shot, your pistons take a beating, but so do your rods, when you spray its like you slamming them with a hammer, and powdered rods suck!! (i popped my motor on a 125 shot, but i was spraying like 2 bottles a week for 2 years)
gonzo275rltw
Sep 5, 2015 06:26 PM
