Few ?s on running lines
Old May 30, 2004 | 08:27 PM
Mr.Whitey's Avatar
What is the longest and shortest distance before the throttle body I can place the nozzle for a wet kit? Also, what is the longest length that I can do from the solenoids to the nozzle? One final question, is it Ok to have the line from the schrader(sp?) valve to the soleniod about 40"?
What I would like to do is have the lines in the following lengths...if possible.
Shraeder valve TO fuel soleniod 40"
Fuel and N20 soleniods TO nozzle 38"
nozzle TO throttle body 22"
Old May 30, 2004 | 11:50 PM
RacinLT1's Avatar
you want the nozzle as close as to possible to the Tbody for good atomization and to keep the gas suspended. the other lengths dont matter,they will just make the hit softer.
if i remember right,the nozzle should be withing 6-8" of the tbody
Old May 31, 2004 | 12:11 PM
12SCNDZ's Avatar
My NX kit says 2"-4" in front of the T-Body. I remember this because I just put mine in Saturday...LOL. Now, I just need that Maximizer.
Frank
Old May 31, 2004 | 12:30 PM
RacinLT1's Avatar
ok,so it's 2-4",been a while since i installed it.
the maximizer is waiting for you.
Old May 31, 2004 | 05:19 PM
Super Slow '97's Avatar
Zex say 6" - 18" from throttle body.
Old May 31, 2004 | 06:01 PM
Mr.Whitey's Avatar
The Zex system is a dry type, right? I guess that would be the reason for the variation in length between the NX and Zex kits.
Old May 31, 2004 | 09:36 PM
Nope that is for the wet kit have the instructions in front of me.
Old May 31, 2004 | 09:54 PM
Mr.Whitey's Avatar
Oh, I didn't even know that Zex made a wet kit. Anybody have an idea why the Zex kit allows the nozzle to be placed further from the TB than the NX?
Old Jun 11, 2004 | 02:09 PM
Zac2003's Avatar
in detail what exactly does the nx maximzer do for you?
Old Jun 11, 2004 | 06:52 PM
RacinLT1's Avatar
the maximizer is a full digital progressive nitrous controller. has many options for initial percent,time for the ramp to 100%,a reset percentage etcd etc etc. basically it's for the tractionally challenged and helps from shocking the rear/suspension too hard if you dont have the good stuff.
Old Jun 11, 2004 | 07:56 PM
12SCNDZ's Avatar
Yup...That's ME!...None of that "good stuff" Everything just as the General made it...Well, except for the Air Lift bag and abscent front sway bar.
Dirk, Next week! I picked up the MSD retard box today.
Frank
Old Jun 12, 2004 | 08:32 PM
96speed's Avatar
Keep in mind how these progressive controllers work...
They pulse the solenoid open/shut quickly. Personally, I don't like the way they work. I would opt for the 'good stuff' and then get some tire .
Ryan
Feffman
Oct 9, 2015 05:42 AM
Jazsun
Dec 29, 2014 12:14 PM
squarehead
Nov 21, 2014 08:02 PM
