Edelbrock nitrous kit - blow down tube installation problems
Old Jun 27, 2002 | 08:15 PM
mtxpert's Avatar
Thumbs down Edelbrock nitrous kit - blow down tube installation problems
Ok I ordered the Edelbrock parts to install their blow down tube and nothing seems to be able to be assembled. Inside the blow-off "nut" that came on the bottle it seems that there is a threaded piece that goes in there that needs to come off in order to install the Edelbrock blow down tube adapter. Anyone deal with this yet?
Mike
Old Jun 27, 2002 | 09:14 PM
KTamez's Avatar
Post
Looking at the bottles on their site looks like they use the same valves as most everyone else does now (except NOS I believe). You should just need to remove the original BD Fitting, make sure you replace the Disc just as it was, with the new 8AN/D-8 Threaded Fitting.
PS, You'll need to have the bottle empty for this.
Kurtis Tamez
LT4-396.com
97 Z28 LT4-396
94 Firehawk LT1-396
Team NW F-Body
Old Jun 30, 2002 | 04:03 PM
mtxpert's Avatar
Post
Well I figured it out. The bottle was a Gen I bottle, I fixed it by just buying a new bottle valve from a local speed shop. Problem solved...
LeftoverChinese
Jan 14, 2024 03:03 PM
alphaauto
Jan 23, 2015 07:42 AM
bandit383lt4
Dec 21, 2014 09:12 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
