Dyno HP curve on a nitrous engine
Old Oct 30, 2003 | 10:58 AM
HeavyChevySS's Avatar
Question Dyno HP curve on a nitrous engine
Does anyone have a picture of a dyno print out of a nitrous engine run without using the nitrous?
Reason being, I ran my Chevelle on a chassis dyno last week without using the nitrous. The engine is setup for nitrous but I am unsure about the exact specs on the camshaft. I basically want to compare my dyno results with someone elses and see if my results are what I should expect or if they show a problem with the engine.
thanks.
Heavy
Old Oct 30, 2003 | 11:02 AM
kmook's Avatar
Advanced Tech Moderator
I dont see that you've tried this in the nitrous forum yet. Let try there as that should yeild the most results. Moving...
Old Oct 30, 2003 | 11:29 AM
LPEdave's Avatar
Here's mine: http://www.go-fast.org/z28/photos/nitrous/n2odyno.gif
You'll see a stock LT1 dyno, then my 383 NA, then the 383 with about 175hp of nitrous.
Dave
Old Oct 30, 2003 | 04:47 PM
My84Z's Avatar
http://community.webshots.com/photo/...86644317dnzGqc here's mine froma couple mods ago
Old Oct 31, 2003 | 11:21 AM
thanks kmook !
Those dyno results are nice, thanks for sharing.
My N/A dyno sheet looks nothing like you guy's N/A runs, both HP and TQ were alot different. Do you guys have NITROUS CAMS in your engines or are they regular cams? cause I am really looking for dyno results from a nitrous engine off the spray.
I am getting my webspace setup to host some pics. Then I can share my dyno results with you all.
Old Oct 31, 2003 | 11:56 AM
My84Z's Avatar
thanx my car is a ls1. On that chart i had a cat back lid and tb. and nitrous on the 100 shot and 150 shot.
Old Nov 2, 2003 | 01:48 PM
'94 Bad A Z28's Avatar
Dave
What kit are you running, those torque numbers seem very low for a 175 shot.
Old Nov 2, 2003 | 02:54 PM
LPEdave's Avatar
Not a kit, just parts. But NOS Cheater solenoids, if that helps. What kind of torque gain would you expect?
Dave
Old Nov 7, 2003 | 09:30 PM
rjames's Avatar
Looks like my old car when I got it done except my fuel program was set up too rich and that will cause a torque drop.
: new link below:
Old Nov 8, 2003 | 07:11 AM
rjames, those links don't work.
says "forbidden access"
Old Nov 8, 2003 | 09:49 PM
rjames's Avatar
Sorry bout that they worked when I posted them .
But click on the link here and go to album titled "Newest pics " they are in there.
Rob
http://community.webshots.com/user/rjjames1
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
Jrlt1
Jan 3, 2015 07:38 PM
bandit383lt4
Dec 21, 2014 09:12 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
centric
Aug 15, 2002 09:04 PM
