Dry Ls1 shot
Old Feb 19, 2005 | 10:46 PM
1984camaroz28's Avatar
Dry Ls1 shot
whats the biggest shot you whould run dry thro a ls1 maf stock fule system stock short block. also anyone no where i can the instructions for a LS1 n20 setup with the wiring digram and relays....i bought a kit thats missing that i will be runing ngk tr6s
Old Feb 21, 2005 | 08:10 AM
Onez4u2bn's Avatar
Re: Dry Ls1 shot
Im a huge noob when it comes to this N20 thing but from my research, im gathering that you only want to spray about a 100 shot, use colder spark plugs and a window switch. (Especially for a M6) I guess the reason behind it is because of the fuel pump and the injectors can't keep up with any shot bigger than a 100. If you go aftermarket injectors and pump then I guess you could maybe go to anywhere up to 150 and be safe? Again, im a total noob to nitrous maybe someone can shed some light on it but thats what I get from my research on here and LS1Tech.com
Michael.
Old Feb 24, 2005 | 12:57 AM
MakoLS1's Avatar
Re: Dry Ls1 shot
With the cars stock tuneing and fuel system i would say 150 safely and could go more but you would start to push it. I shot a 150 for a long time. Just get tr6 plugs. Autolite 605s are the same heat range as a tr6 and they worked fine for me when i used them.
Formula Steve
Sep 19, 2023 08:31 AM
13qtr
Oct 28, 2016 08:11 PM
RUENUF
Mar 13, 2016 03:37 PM
damnyankee36
Sep 9, 2015 07:06 PM
Boss002
Jul 24, 2015 10:47 AM
