does it realy matter if you heat your bottle
Old Aug 17, 2006 | 09:46 PM
rockholt454's Avatar
i just ran at the drag strip it was an 1/8 mile track and i ran an 8.5 with no nitrous with nitrous was an 8.2,what could the problem be i felt the nitrous come in but it just wasnt the much of a difference in power,by the way this is a 100 shot dry on an 01 z28
Old Aug 17, 2006 | 10:36 PM
96speed's Avatar
Re: does it realy matter if you heat your bottle
Heck yeah it does. Heat has a near linear relationship with pressure. IOW, if your bottle is too cold, your pressure is too low. Why is this bad? Not enough pressure will not create the proper mix of nitrous/fuel 9read: more fuel).
A heater should come standard in kits. It is as mandatory as having a window switch, IMO.
Ryan
Old Aug 17, 2006 | 11:01 PM
speed_demon24's Avatar
What was your 60' and mph for both runs?
Old Aug 17, 2006 | 11:45 PM
97SS0594's Avatar
heat is very very important! you want to keep your bottle pressure right around 900-1100, if you dont have a pressure guage get one!!
Old Aug 18, 2006 | 09:11 AM
gforcejunkie's Avatar
your bottle pressure should be between 900-1050. after 1050 it hits the critical point of nitous which if your running the track you will hate anything higher then 1050.
Old Aug 18, 2006 | 11:26 AM
2000GTP's Avatar
If you want to maintain consistency with your bottle runs, then a bottle heater is the way to go.
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
CARiD
Sep 30, 2015 05:44 AM
Daluchman1974
Sep 11, 2015 06:12 AM
damnyankee36
Sep 9, 2015 07:06 PM
