Does nitrous...
N2O does not break down into nitrogen and oxygen until it reaches about 600*F, so its unlikely that it would affect anything up to and including the intake valve. Its sure going to clean your plugs off if you have a "too hot" plug... but that might include removing the ground strap as well.
Shell is currently advertising "nitogen fortified" gasoline. How would a gas that doesn't burn "fortify" gasoline? When you check into what they are actually selling, its a nitrogen-based detergent compound (additive) that is supposed to clean the valves..... misleading advertising at best.
Oh yea it will clean out a lot of crud, piston rings, ring lands, valves, and rods sometimes
haha
I didnt take any short cuts, so it should be safe right
? FPSS, pulled -3 of timing, a/f ratio is at 11.8-12.0 tr6 @.036 and I only run 93 octane.
Im more worried about the glass tranny taking a dump...N2O does not break down into nitrogen and oxygen until it reaches about 600*F, so its unlikely that it would affect anything up to and including the intake valve. Its sure going to clean your plugs off if you have a "too hot" plug... but that might include removing the ground strap as well.
Interesting....
ULOOSE
Mar 3, 2008 06:16 PM
