does it matter how you install the n20 nozzle?
Old May 2, 2004 | 11:04 PM
QCKZ28's Avatar
im going to install a zex dry lt1 kit, and im going to be very stealth about it.....
i want to install the n2o nozzle on the bottom side of my 1LE elbow, instead of the top.
will it matter?
jesse
Old May 2, 2004 | 11:57 PM
ltwonz's Avatar
As long as its facing the throttle body it won't matter.
Old May 3, 2004 | 12:49 AM
QCKZ28's Avatar
im going to try to mount the zex FMU box under the dash on the pass side.
i will probably need a longer nitrous line to from the FMU to the nozzle.
i will put the bottle in the spare tire well, and run the n2o line under along the door seal under the carpet.
i will have to extend the TPS wire to reach the FMU box, and extend the tach wire to feed the window switch.
i may also have to have a longer vacuum hose than supplied with the kit......
thanks
any other things im forgeting?
Nov 18, 2023 07:21 PM
ldtantlinger92
Jan 19, 2015 01:26 PM
LS1 RULZ
Aug 11, 2002 11:15 PM
super83Z
Jul 11, 2002 10:16 PM
