Couple of N20 questions
Old Apr 24, 2004 | 04:55 PM
94NDTA's Avatar
First one is, I looked through my NX manual, and it said to not let the bottle pressure get below 1000psi, and not above 1050 psi or else it will run rich/lean. I have a bottle heater, but ho will I know when the pressure is too high or too low without going back to the bottle and looking at it? Also, Where I mounted my bottle, it touches the back of the car and the side mounting peice in the wheel well. If I put a peice of rubber between these places, will the bottle get too hot for them when the warmer is on?
Old Apr 26, 2004 | 01:21 AM
slp223's Avatar
you will have to check the guage or buy a swithced heater the turns itself on and off based on bottle pressure. the bottle should not get hot enought to cause any problems with the rubber.
Old Apr 26, 2004 | 08:18 PM
94NDTA's Avatar
Doesn't the NX bottle heater do that?
Old Apr 26, 2004 | 09:12 PM
slp223's Avatar
yes the NX does I think the ZEX and TNT do also.
squarehead
Jan 15, 2015 07:02 PM
Jan 13, 2015 09:52 PM
ChrisFrez
Jan 4, 2015 08:43 AM
pete53
Dec 9, 2014 07:31 AM
T/A lt1
Oct 10, 2002 03:14 PM
