Constant miss when spraying
I have a Nx kit , when I spray it have a constant miss, almost like hitting teh rev limiter, imstill running stock gap oon some old autolite plugs , is this teh problem? anyhelp
Re: Constant miss when spraying
It very well could be. Why not replace them? That way you can atleast rule them out if it dosn't solve the problem.
when i had my 94 z28, i changed the plugs and wires. went away for about a month. ended up putting a mallory hyfire IV ignition box on. solved the problem. the stock ignition coil just wasn't enough to handle the n2o.
tommalcolm
Sep 11, 2015 03:39 PM
