Can a stock LT1 handle a mild nitrous shot?
Old May 4, 2004 | 11:58 AM
brians96Z's Avatar
Question Can a stock LT1 handle a mild nitrous shot?
Can I put a mild nitrous setup on my 96Z? (Stock)
Old May 4, 2004 | 08:25 PM
roadrage912's Avatar
you can run a 100 shot with no problem. i'd suggest upgrading the ignition if you go any more than that. you will need to change plugs and gap for sure though. and definitely go wet.
Old May 4, 2004 | 08:28 PM
Frans96SS's Avatar
u can run 150 just make sure u have the fuel for it i have an intank pump and 30 pound injectors but i ran it with no ignition for a long time
Old May 4, 2004 | 08:35 PM
i don't think 30# injectors are quite stock. like i said i wouldn't go more than 100 shot stock.
Old May 4, 2004 | 08:52 PM
GJE94Z28's Avatar
Cool
Yes, yes, yes...you will love it!
Old May 5, 2004 | 02:18 AM
SJBlackZ28's Avatar
I just started running 100shot bro and my car has 160k so you should be fine. I didn't up grade anything so it a stock LT1 and 100shot. I use to run 75shot for like 2 month and had no problem so you should either.
Old May 5, 2004 | 09:29 AM
chevy1963's Avatar
I'm running a 150 wet shot with stock plugs and no timing retard. I increased my times 1.28 seconds
Old May 5, 2004 | 12:39 PM
Derrick Redd's Avatar
NX 175 shot here. 76k stock shortblock still rolling.
Old May 5, 2004 | 12:46 PM
chevy1963's Avatar
hey, so your car is completely stock, except exhaust? and your running 175 shot? I'm running a compur plate wet kit, what jet numbers should use to run the 175 shot?
Old May 5, 2004 | 07:53 PM
RacinLT1's Avatar
i ran a 175 shot on a 99.9% stock longblock (had 1.6 rockers).
I did swap the fuel pump (smart thing to do) and had a msd digital 6 to pull some timing. engine had 64k miles on it.
pulled the engine to step up the program and everything inside was perfect.
Old May 6, 2004 | 05:40 PM
12SCNDZ's Avatar
I figured you'd jump on this thread...LOL. You forgot to mention the stock motor went 11.0's with the 175 shot.
Frank
Old May 10, 2004 | 03:16 AM
neil350's Avatar
Colder plugs and you'll be good to go, Lt1s love nitrous
Old May 14, 2004 | 12:35 PM
BIGDOG_7's Avatar
I too have a stock lt1 and would like to get a nitrous kit to put on, any recommendations on what I should get for it (brand, model #).
Old May 14, 2004 | 03:01 PM
blind527's Avatar
i have a 97 formula...im def. doin ZEX's wet nitrous kit, activiates at open throttle....does anyone know what the gap should be??? im already purchasing autolite 104's
Old May 16, 2004 | 09:26 PM
mrr23's Avatar
i used the NOS 05176 dry kit on my 94 z28 years ago. went from 13.60 to 12.24 @ 113.90 auto with 2.73 gears. it comes with another inline fuel pump for the added fuel needed. it's set to 125.
