Can bottle warmer tap into defrost for power?
Old Feb 26, 2003 | 05:51 AM
therealmagyver's Avatar
I wanna know if I can tap into the the rear defroster with the bottler warmer.
Old Feb 26, 2003 | 09:00 AM
stik6shift98's Avatar
yes but it will only work when u defrost your window....
Old Feb 26, 2003 | 09:28 AM
On a large power consumer like a bottle heater or fuel pump, you are generally better off running the correct, heavy gage wire directly from the positive terminal in the red box near the battery, including a fuse in the line, and connecting it through a relay.
If you were no longer using the rear window defroster, you could check the wiring size and relay capacity, disconnect the wiring from the defroster, and reconnect it to the bottle heater if it was the right size. Make sure you don't let anyone else turn on the "rear defroster"...... .
Interesting idea.........
Old Feb 26, 2003 | 10:47 AM
95greendragon's Avatar
I wouldn't do it. I doubt the defrost relay and fuse are up to it. It draws current like a mother.
Old Feb 28, 2003 | 02:58 PM
n2oTransAmLT1's Avatar
Also...the defroster only stays on for a few min...right? If so, it wouldnt even have enough time to heat the bottle.
Old Feb 28, 2003 | 07:30 PM
stik6shift93's Avatar
Just run a wire from the positive terminal like injuneer said, all you have to do is run it threw the firewall(there already a hole behind the cpu to run wires threw) wire it to a switch and then just follow the rest of the directions the warmer came with.
Old Mar 2, 2003 | 08:08 PM
JustaLT1's Avatar
Actually, I have my bottle heater hooked up to the defroster switch. I simply disconnected the power wire from the defroster and ran it to my bottle heater. It works great and is quite safe IMO. The reason I say that is because the defroster has a timer on it, so after 12 (I think) minutes it automatically shuts off. Works great for me, and I've had no problems.
Old Mar 3, 2003 | 07:48 AM
HeavyChevySS's Avatar
If you pull more current on a wire that is under sized. It could take a while for a problem to appear !!! Just cause it works fine in the beginning doesn't mean it is fine. You can cause a hot spot at the weakest point in the circuit and in turn start a fire.
If you look at the size of the wire on the defroster and compare it to what the heater kit is calling for; you can determine if it will be safe or not.
Ex: defroster wire is 16 gauge
heater wire needs 12 gauge
Smaller gauge means larger wire!
NOT good!
Just be careful !!!!
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
bandit383lt4
Dec 21, 2014 09:12 PM
XtremeLt1
Sep 13, 2002 08:50 PM
