I need a blow down tube that i can easily more around and bend, basically I need to go down with it and then out an existing hole under the bottle. Can I just use normal bradied nitrous line with an attachment on the outside of the car to hold the end outside? Would this pass track inpection?
Have you ever had it to the track, did it pass tech inspection? This is what I am mostly worried about.
I use a braided -8AN line. Screws directly onto the relief valve, and connects to a bulkhead fitting on the floor of the hatch. No reason it wouldn't pass tech.
The line won't see excessive pressures as it's open at one end.
I wasn't worried about the hose breaking, more of it being a very technical/picky at the track about it not being a solid tube so it doesn't flex.
Thanks guys
Thanks guys
