Blow down tube?
Blow down tube?
I need a blow down tube that i can easily more around and bend, basically I need to go down with it and then out an existing hole under the bottle. Can I just use normal bradied nitrous line with an attachment on the outside of the car to hold the end outside? Would this pass track inpection?
Re: Blow down tube?
I use a braided -8AN line. Screws directly onto the relief valve, and connects to a bulkhead fitting on the floor of the hatch. No reason it wouldn't pass tech.
14
Aug 11, 2015 12:03 PM
