Biggest shot through a fogger
Old Apr 19, 2007 | 01:13 PM
walt355's Avatar
As of now i have 2 fogger nozzels tapped into a trick flow elbow. I am using cheater soliniods and planning on going through a Y fitting for both nozzels(wet of coarse). Ive been told that is isnt safe to spray much past a 175 shot through the front of the intake due to starvation of the bacl cylinders. Any suggestions? I was planning on running a 225-250 shot. I dont have the spray funtional at all now.
Also Im looking for a good pic of a direct port setup on a stock lt1 Intake manifold
Old Apr 19, 2007 | 02:10 PM
Ray@NitroDaves's Avatar
200 is the most we reccomend spraying on the LT1 intake manifold...anything above that should be run through a direct port.
Also if you are planning on spraying above 150 pay close attention to the spark plugs as they will give you a good indication if you are having distribution issues.
Old Apr 19, 2007 | 05:48 PM
walt355's Avatar
Thanks man. Am I right by saying that a single fogger jet is on;y good for a 150 shot?
Old Apr 19, 2007 | 06:06 PM
2000GTP's Avatar
You shouldn't have any issues with that jetting on a single nozzle.
Old Apr 19, 2007 | 07:22 PM
Jlo's Avatar
Jlo
why does NX sell there race kit that spray's 100-250 on a single nozzle?? can a single nozzle handle 200hp hit.
Old Apr 20, 2007 | 09:45 AM
The NOS Black nozzle can only flow ~150hp...the NX and Our Single Nozzle will flow ~250+.
The NOS nozzle has a smaller internal orifice
Old Apr 21, 2007 | 08:49 PM
Jlo's Avatar
Jlo
But how will that work in an LT1?? a single nozzle with say a 250 or 200hp hit?? would there be a distribution problem??
Old Apr 22, 2007 | 02:36 AM
Daniel6718's Avatar
throught 1 nozzel..probably..look more into a plate if you want that big of a stage...
Old Apr 22, 2007 | 12:52 PM
2000GTP's Avatar
With the LT1 intake, yes. If you want to go with anything over 200, it is best to ditch any setup other then a direct port.
Formula Steve
Sep 19, 2023 08:31 AM
68camaroboltz
Oct 5, 2015 11:56 PM
Sep 18, 2015 03:46 PM
NewsBot
Sep 15, 2015 11:53 AM
damnyankee36
Sep 9, 2015 07:06 PM
