best N2O gear
Old Jul 18, 2002 | 10:03 PM
bt96ss's Avatar
Post best N2O gear
I currently have a auto 3.23 car and I use a NX 150 shot. Because of a whinning rear I and going to upgrade my gears. I was really leaning toward the 3.42 because I like to drive long distances and I dont want to be in overdrive at the end of the quarter. THose of you with 3.73 please respond with how they respond to nitrous and what gear and rpm you are at the end of the quarter. Thanks.
Old Jul 19, 2002 | 12:38 PM
speedmiser's Avatar
Post
3.73s will get approx 20-22mpg on the highway at 70-80mph with a 26"tall tire.
In the quarter with the 26" tire, you shouldnt have to worry about running out of gear in 3rd, until you obtain 120+mph trap speeds.
If I'm playin, I'm sprayin
93 Z28 A3 - w/ Jet Hot coated Hooker LT's and true 3" duals
(hiflow cats, cutouts, and Car Chemistry insert mufflers)
Old Jul 19, 2002 | 12:56 PM
Derrick Redd's Avatar
Post
I'm running 3.42's. I'd go 3.73 NA and 3.42 with a power adder.
<A HREF="http://personal.msy.bellsouth.net/msy/k/r/kraest/derrick.htm" TARGET=_blank>1994 Z28 A4
LT1 Motorsports equipped stock-bottom end LT1, LT1 heads, Hydraulic-Roller Cam, Dope
11.03 @ 125.53 1.61 60ft.
7.08 @ 99.05 1/8 mile</A>
1984 Mustang L
92' 5.0 roller motor, T5, etc.
14.03 @ 100.51 with a spinning 2.29 60ft.
Old Jul 21, 2002 | 10:05 AM
George Debski's Avatar
Post
It depends on your converter. With my 3800 stall, 3.73s and 26" tires, I hit the rev limit (6500) around 100' before the traps, due to converter slip. As a result, I've only been able to hit 117.9 so far, when I know there is more available.
With the TH400, I have no OD, so either I need 27" tires or a Gear Vendors.
When I had the 2400 SLP TC and the 4L60E, I had no problems getting over 120 at top of 3rd. (not at the track, though )
SSMOKEM
1995 Impala SS "Cherry Bomb"
Best ETs: faster than my '65 pickup
Mods: 93% stock
My Super Impala SS Website
[This message has been edited by George Debski (edited July 21, 2002).]
Jlo
Feb 3, 2015 09:41 PM
taner
Aug 26, 2002 10:58 PM
taner
Aug 23, 2002 05:25 PM
taner
Aug 21, 2002 09:49 AM
taner
Aug 18, 2002 08:43 PM
