ALL the safety items.
the list looks good. eletric tps is more of a convienence thing,i have run micro switches for 10 years with never a problem.
injectors and pump will be fine for a 100,150 has been done on stock fuel pumps,and since you have a new 1,it will be better then having an old pump,but not quite as good as a high flwoing pump.
You can reduce the risk of failure with a micro switch by using things like loc-tight on the threads used to attach it to the bracket, run a couple of wraps of tape around the switch to ensure if a nut comes off, the bolts don't come out, and cut the additional length of the 'arm' off so it won't get stuck under anything. Just be careful. A TPS just has many less points of failure, and hence is a safer unit.
im still trying to figure out how a nut came off and caused the throttle to stick. everytime i have mounted a switch,nothing coulf prohibit the throttle from closing fulling if something fell off.
sorry to hear what happened.
When the nut came out, the switch dropped and was hanging by only one bolt. When I went to WOT, the cam wedged itself under the micro switch, and was unable to return to closed position, hence sticking the throttle at WOT.
Put the car in neutral and began to hit the brakes, and then the car was bouncing off rev limiter. Went to turn the ignition off, and the steering column locked. Unfortunatly it locked at a slight turn and at 120MPH it don't take much to go off the road. Fortunately I was able to turn the key back on and steer past a phone pole which I missed by about 18". After that, it was into a vineyard, and the car came to rest with damage on all sides. I was lucky I missed the pole, or I'd not be here today.
All in all, there are lots of things that if done differently, could have avoided the situation. Had I not been street racing, I wouldn't have totalled the car. Had I not mounted the micro switch on top of the TB, it probably wouldn't have stuck. Had I not cut the arm so short, I probably wouldn't have had to mount it so close to the cam on the TB, had I used lock tight on those tiny little bolts, one probably wouldn't have come out. etc, etc, etc. My main point was, an electronic TPS is an easy thing that can mitigate a lot of risks. Certainly won't make everything fail safe, just one of those added security measures.
-Keith
RUENUF
Mar 13, 2016 03:37 PM
