2 questions?
Old Mar 2, 2003 | 09:01 PM
qwick_trip's Avatar
2 questions?
ok i got a moser 12bolt rear end can i spray off the line? i got a 6speed with a 150dry shot. second question i got a msd window switch should i shut it off with that or should i let the wot switch shut it off?
Old Mar 2, 2003 | 10:40 PM
94z'sson's Avatar
sure you can spray off the line with a 12 bolt i am doing it with a 9inch but if you dont have any suspension (good) you are goin to need it. and as for the window switch i would set it at where you expect to shift and have the WOT be the back up to shut it off! but if you shift at 6000 have the window at 6000 and when you let off the gas to shift the WOT will cut it off but it will get power as soon as you are floored agian
Old Mar 2, 2003 | 10:45 PM
qwick_trip's Avatar
i will have the complete hals setup and slicks. good enough or not? also what gears are better 3:73 or 4:10
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
