175 and or a 200 shot sizes
Old Nov 15, 2003 | 12:01 PM
JucinGTA's Avatar
What is the Jetting for both on a NOS Kit? I have a kit I made with NOS parts that I made which has dual nozzles.
What would a 175 and a 200 shot be? I will just split the numbers that you guys got.
Old Nov 15, 2003 | 07:38 PM
rskrause's Avatar
Moderator
No, you can't divide jet size in half.
Example: for a 100hp shot with 1000psi bottle pressure and 55psi fuel pressure (what I run) the right nitrous/fuel jets is a 47/25. For 50hp it's 37/20. So, to get 100hp you could run one 47 jet or two 37's. The numbers refer to the diameter of the jet orifice. Flow is proportional to the area of the orifice and the area is proportional to the square of the diameter. So, doubling the jet size increases the nitrous flow by ~4 times. And dividing the jet size in half will provide ~1/4 the nitrous flow.
Rich Krause
HectorM52
Jul 30, 2017 11:46 AM
sbusaidi90
N2O Tech
Apr 22, 2015 06:51 AM
nikolt1
Feb 27, 2015 09:10 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
