150 shot too much?
Old Mar 22, 2008 | 05:58 PM
F(ast)-body's Avatar
150 shot too much?
Stock bottom end H/C LT1 with 79,000 miles.......got the 100 shot now, am I risking a blowup going to the 150's??
Old Mar 22, 2008 | 08:53 PM
SPEEDY96T/A's Avatar
I GOT A 150 SHOT WITH M/T D/R's AT 116 AND MY BRO 155K WITH A 150 SHOT WITH NITTOS UR ALL GOOD PROBLEY BETTER THAN UR MOTOR SHOOT IT UP DONT WORRY HAVE FUN.WAIT TILL YOU HIT THAT 150 SHOT OFF THE LINE ITS A BLAST MAKE SURE U GET M/T D/R's I THINK THEY ARE BETTER
Old Mar 22, 2008 | 08:59 PM
2000GTP's Avatar
Depending how aggressive your heads/cam setup is, a larger shot of nitrous may be pushing it, it may not. Its always a hit or miss, but something you should keep in mind by keeping a rebuild in mind for the future. Make sure you are getting plenty of fuel and you may have to have some timing reduced.
Old Mar 22, 2008 | 09:10 PM
MY HEADS AND CAM 100% STOCK AND MY BROTHERS 5THE ONLY THING WE HAVE ARE DOWN BELOW
I GOT A MALLORY 365 "I THINK"DONT MARK MY WORDS .....................BUT I ALSO GOT HEADERS AND EXHAUST.IM ALSO PUTTING IN A ELECTRIC CUT-OUT NEXT I GOT SO FAR A CAI,HEADERS/EXHAUST,STOCK GEAR AND TRANS JUST LETTING YOU NO,MSD WIRES/COIL AND NEW PLUGS "NOT SURE WHAT KIND" BUT I WOULD DEFINITLY GET RETARD THE TIMING "SORRY 4GOT TO MENTION"ITS LIKE I THINK 200 BUCKS OR SOMETHING.ALSO I GOT A CHEAP *** THING THAT WORTH A MILLION BUCKS TO ME http://store.summitracing.com/partde...5&autoview=sku
TAKES ABOUT 5-10 MINUTE TO HOOK UP AND WEDGE BETWEEN THE DRIVER SEAT AND CONSOLE.I USE THIS ONLY WHEN I USE MY NOS AND I LOVE IT CAUSE IT HITS SO HARD.
GOOD LUCK
Old Mar 23, 2008 | 11:26 AM
I already have 3 degrees pulled outta the timing with the 100 shot. I run ET Streets and they are hooking so far. I launch at 4000 RPM. Oh, forgot to mention my car is a 6-speed. What I read is pretty much what I'm hearing. It's pretty much a chance the motor might blow and it might hold together....no way of really knowing. Just roll the dice and see what happens......
Old Mar 23, 2008 | 11:27 AM
2000GTP's Avatar
MT ET Streets and an M6.... you have a better chance of blowing your rearend first rather then the engine.
Old Mar 23, 2008 | 02:22 PM
jasonface's Avatar
It's on the edge, stock LT1 pistons are crap. Make sure you pull enough timing to keep it out of detonation. I promise you the very first time you get detonation while spraying you'll break a ring land. So, spray it, have fun, and plan on building a new engine soon anyway--that's the safest plan
Old Mar 23, 2008 | 10:23 PM
man i ****ed **** up on my car from thinking i had enought nos , but little did i no i had none and blow the maf and the inner hood liner was even on fire lol so i fixed it and called it aday 200 bucks.make sure you pressure is right b4 shootin i shoot anywhere from a 950 - 1025 range no problems.i even use it when im bored at a light just because its so fun.your only get 4 runs out the 10lb bottle.just make sure you count even if you use it for 2 sec's that counts as one.i use it at a 1/4 mile at a time.my brother will let it rip on the hwy for atleast 2 miles lol.
Old Mar 23, 2008 | 10:30 PM
69gto96z's Avatar
I wouldnt push the stock bottom end much past 550 fwhp, I wont push mine much past 500. I would say a 150 shot on a h/c motor making over 400 on motor would hold up 4 a while, but keep a new motor in the back of your mind.
Old Mar 23, 2008 | 11:00 PM
Z-RATED94's Avatar
468rwhp here on a 115 shot. Only 4 passes so far, but will bump it up to a 150 shot. Looking for a high 10 or breakage, we will see which comes first.
Old Mar 24, 2008 | 07:21 AM
2000GTP's Avatar
Where did you dyno it at Rick, Speed Inc.?
Old Mar 24, 2008 | 07:38 AM
jasonface's Avatar
Old Mar 24, 2008 | 11:24 AM
Z-RATED94's Avatar
Yes I did Chris, the new Yank lowered the NA pull compared to the smaller Vig., as it should. 353rwhp unlocked, SAE. The fuel pill is a couple of sizes to big for now and they pulled 8 degrees of timing with the 685 box. Trying to play it safe and sneak up on the 150 shot.
Old Mar 24, 2008 | 11:42 AM
2000GTP's Avatar
Well done on the numbers, did you ever pick up that shortblock?
Old Mar 24, 2008 | 11:46 AM
Z-RATED94's Avatar
Yes I did, and if you have so much time on your hands, bouncing between web sites, get your butt over here and start taking it apart.
