125 shot???
Old Jun 8, 2007 | 04:53 PM
96SilverZ's Avatar
125 shot???
Right now I'm running a NX 100 shot in my 96Z(mods in sig). Whenever I use the nitrous I mix a couple gallons of 110 into a full tank of 92 octane gas. Can I run a 125 shot like this or not?
Matt
Old Jun 8, 2007 | 08:54 PM
Ray@NitroDaves's Avatar
you will be fine
Old Jun 9, 2007 | 12:36 PM
69z-28's Avatar
with the right safety stuff no problem. i did a 75 shot with all the safety stuff on straight 93 and will be running the same with a 125 shot soon. good luck
Old Jun 10, 2007 | 06:58 PM
96SilverZ's Avatar
Thanks guys. I forgot to mention I do have Speed-Pro forged pistons too...
Old Jun 11, 2007 | 08:50 AM
with the mods you have listed you will be fine up to 150 as long as the fuel system can keep up
Old Jun 11, 2007 | 09:54 AM
69gto96z's Avatar
I run a 150 shot on stock bottom end, Walbro 255 fuel pump, and 93 pump gas.
Old Jun 11, 2007 | 06:15 PM
96SilverZ's Avatar
Walbro 255lph pump
Old Jun 11, 2007 | 10:02 PM
Walbro 255lph pump
smart answer.....if you have just the pump it will support ~550whp...if you have a dedicated pump harness it will support ~650whp
Old Jun 12, 2007 | 02:17 PM
nfa's Avatar
nfa
I have run 150 wet shot on stock bottom end with autolite 104's, 94 octane, racetronix pump/hotwire kit with out any problems (other than a slipping clutch!!!)
LT14LIFE
Nov 15, 2015 06:22 PM
68camaroboltz
Oct 5, 2015 11:56 PM
Sep 18, 2015 03:46 PM
NewsBot
Sep 15, 2015 11:53 AM
damnyankee36
Sep 9, 2015 07:06 PM
