Mountain Arizona, Colorado, Idaho, Montana, Nevada, New Mexico, Utah, and Wyoming
Names Of Auto Shops/mechanics You Trust.
Old May 27, 2003 | 01:12 PM
  #61
CARGUY's Avatar
Originally posted by Wild1
MMO - Marvel Mystery Oil. Available at nearly all auto parts stores. http://www.foximas.com/auto/marvel-m...oil--16-oz.htm Brief description.
No I didn't. Only because the check engine light came on so I thought it would be pointless. Do you agree?
Old May 27, 2003 | 07:27 PM
  #62
Wild1's Avatar
It's tough to say. A locked injector could cause a lean condition / misfire. Especially if it is intermittant. I have several scantools at my disposal that can read your codes. They don't always indicate the failure, but that something is out of spec.
It wouldn't hurt to put in the MMO. But I could pull your codes anyways. What year is your Camaro?
Old May 27, 2003 | 07:39 PM
  #63
CARGUY's Avatar
Wild1- It's a 97 m6
Old May 27, 2003 | 08:48 PM
  #64
Wild1's Avatar
You're local. I can run the scanner or you can go by Napa or Kragen and they can pull your codes for you. We can go from there...
Old May 27, 2003 | 09:00 PM
  #65
CARGUY's Avatar
Cool man, I'll just stop by one of the auto parts stores. No need to put you out, but thanks for all your help. I might end up taking it to Mark at Andy's since he's helped me out before. It's just going to be tough getting out to Monrovia with my work schedule.
Old May 27, 2003 | 10:06 PM
  #66
Wild1's Avatar
No prob. When you find out what it is, let me know.
Old May 28, 2003 | 03:46 PM
  #67
Wild1's Avatar
Carguy - It sounds like you addressed the Ignition issue but we should still check out the MIL (Malfunction Indicator Lamp). You still have many other options to check but the codes would be a big help…
Fuel – Fuel Pump, Regulator, or Filter
Sticking Throttle Cable – Disconnect and spray some Teflon lubricant down the cable (inside)
TPS – corrosion, bad connection, out of adjustment, or malfunction
ISC – Malfunction or Dirty
O2 – Bad sensors (could be from a coolant leak)
Something not connected to the sensors or the mice may be eating the insulation
Vacuum leaks – but you said it was intermittent so this isn’t likely
I'm really curious what codes they pull...
Old May 28, 2003 | 03:47 PM
  #68
Wild1's Avatar
Josh at JD Performance in Huntington Beach...
714/847-4257
Let him know Greg sent ya... he may cut you a deal. My 69 is there getting some TLC.
Old May 29, 2003 | 12:57 PM
  #69
CARGUY's Avatar
Exclamation
Wild1- What makes MMO better or different than putting Seafoam in the gas tank? I ask this because I did'nt mention that I did the Seafoam thing a couple weeks before I did the opti/coil/plugs/waterpump.
Old May 29, 2003 | 04:32 PM
  #70
Wild1's Avatar
MMO is more of a lubricant even though it does clean. It will help lubricate the rubber (Injector pintle seats, o-rings in the fuel pump, etc.).
Marvel Mystery Oil can be added to gas or oil (not synthetic). It combats internal motor rust and corrosion, lubricates valves, piston rings, upper cylinder walls, and eliminates valve sticking. Keeps rings free and reduces piston and cylinder wear. Also keeps fuel pump and carburetor parts clean, eliminating the need for frequent adjusting. Marvel Mystery Oil retards formation of power dissipating motor deposits, such as gums, varnish, and sludge.
SeaFoam is great! It is primarily a cleaner/decarbonizer.
I hope that helps...
Old May 29, 2003 | 05:13 PM
  #71
CARGUY's Avatar
Yeah it helps, thanks! I was surprised to find nothing about it on a search though?
Old May 29, 2003 | 08:07 PM
  #72
Z28Girl's Avatar
I bought my Z from showcase chevrolet! So yeah, it's close and I just want to do a catback, no headers yet. JD's is literally right by my house. I live at beach/garfield. So I could practically walk there. This is so cool. Thanks a a lot!
Old May 29, 2003 | 10:23 PM
  #73
Wild1's Avatar
No problem....
Cat-Backs really aren't that difficult. Takes about 3-4 hours. I did mine in the driveway.
When I did the headers, I was glad I had the shop at the time and access to a lift. If you're handy with tools, we can guide you through it.
Old Jul 2, 2004 | 01:11 AM
  #74
Vash's Avatar
Gary's complete Automotive Service
323 569 4763 ask for Richard
Old Jul 3, 2004 | 09:41 AM
  #75
Wild1's Avatar
It's great to have a list of great mechanics. Josh did some good work above and beyond on my car. He backs up his work as well... doesn't push you out the door.
Greg
