Mountain Arizona, Colorado, Idaho, Montana, Nevada, New Mexico, Utah, and Wyoming
5 speed advice
Old Nov 16, 2004 | 05:16 PM
chevyguy75's Avatar
5 speed advice
I have a 69 Camaro with a 4spd. I am looking to swap it out for a 5spd. Anyone have any good advice or maybe who I should buy through?
Old Nov 16, 2004 | 10:05 PM
SAM98TAM6's Avatar
Re: 5 speed advice
Not sure about a 5-speed, but Tyler at American Touring Specialties has a kit to bolt in a T56 6-speed.
http://www.t56kit.com/site.html
Old Nov 25, 2004 | 01:25 AM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Re: 5 speed advice
A Richmond 5-speed or a Tremec TKO 5-speed. Dont bother with a GM T5. Even better is a T56 like suggested above.
Old Nov 28, 2004 | 12:00 AM
SVThuh's Avatar
Re: 5 speed advice
A really good friend of mine swapped in a T-56 from his totalled 94 camaro into his 67RS. Built 327 and a six speed with 4.56 gears makes for a NICE combination....
He got an adapter plate from Mcleod and then converted the input shaft on the trans to the LS1 style input shaft (non-pull type clutch) and was able to use his mechanical linkage from the M-21 that he had in there. You will need to use a bellhousing from a SBC and a clutch for a LS1, but I think you can use a regular style Pressure Plate... You will also have to modify your trans crossmember... Nice setup though and it puts the shifter back a few inches which makes for a really nice shifting position...
Just FYI
Jun 6, 2015 08:27 AM
alex5366
Apr 1, 2015 09:27 AM
jj_burchiel
Mar 21, 2015 12:51 AM
grabbem88
Feb 10, 2015 06:20 PM
Notford95
Aug 20, 2002 01:46 AM
