Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Want to convert to E85????
Old Dec 15, 2009 | 10:40 PM
detroit1994z28's Avatar
Have a 95 z28. Car is currently tuned to run on 93 pump gas. I wanted to eventually run more boost and have it tuned to run on E85. The car has 60# injectors I beleive with two walbro fuel pumps and all custom stanless steel braided lines custom ran into the intake. What's everything I have to change, upgrade to run E85 - I'm new to all this stuff.
Old Dec 18, 2009 | 07:39 AM
ws6transam's Avatar
As far as I know, all hard lines are good to go in terms of E85. All seals that have been manufactured since about 1985 are also good for E85, since ethanol has been a chief component of modern gasolines as an anti-knock additive since the mid-80's.
You've increased your fuel delivery....added the requisite 30% additional volume capacity to your injectors... About the only two things I can think of is to double-check with the manufacturer of the braided stainless lines to ensure that the inner material is ethanol resistant, and the second is to get an E85 tune into the computer. Which system do you have?
Fast systems are capable of handling four separate, switched fuel maps, and can also be set up with fuel type multipliers in the lamda calculation for closed loop WOT operation with wide band O2 sensors. That's what I've got and I'm thinking hard about E85 as well.
2QUIK6
Sep 17, 2016 02:31 PM
95craz28
11
Sep 12, 2015 07:47 AM
USN06
Sep 7, 2015 03:30 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
Aug 5, 2015 08:35 AM
