Still have the same problem
Ok guys, I replaced the crank pully today to rid myself of the wobble and hopefully stop eating belts. No luck, anything above 4 grand and the belt walks off the pulley and eats itself. Anyother ideas?
Q
Q
is the tensioner spring functioning and free moving?
Break it down...what happens at high RPM? the belt gets warmer and expands...it spins faster, so it expands due to centrifugal force. Does the tensioner move when it needs to?
j/k I never thought of it that way Mike, but you make a good point. I guess that is the next step....new tensioner. Just kills me that it worked when we pulled it out, but now it wont work. Just dosent add up.Q
Originally posted by dreamer1q
A very good question....care to ride under my hood and watch
Q
don't need to ride under the hood. Just get someone in there on the gas pedal or grab hold of the throttle body yourself and slowy bring the rpm up maybe 1k at a time. Check EVERYTHING, then go another 1k and repeat. See what happens. Put some safety glasses on first though
Q
Usually a belt that "walks" is caused by a pulley driven by the smooth side of the belt. So make sure idler(if you have one) is ok too. Unless the bearings are about gone or way off the belt will stay in the groove. I think before you mentioned it was walking off the P/S, I'd check the smooth pulley before it(if there is one).
Q, I'll give ya a hand! I don't like myself right now anyway. I met this perfect girl and there is no way that I am enough of a "pimp" to get her to settle down with me so this making me feel a little bit horrible right now... almost like I wanna have a belt shot into my face
sorta kidding... anyway, Q, call me tomorrow. I'll be outta work at 7. But, Melanie is coming over for a sex fest. I don't understand her.
....Ya ho I'm legal again.Q
Re: Still have the same problem
Wow, old post.
Mine ended up being the spacer on the alternator. Removed it and I was fine. Use a straight edge and see what is sticking out where it shouldnt be. Even the new laser levels would work too, wish I would have had one of those back then.
Magenta_Hearts
Mar 25, 2015 10:24 AM
