Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Removing axles from 12 bolt??? Need help
Old Jun 8, 2007 | 02:07 PM
detroit1994z28's Avatar
Just wondering if anyone here knows how to remove axles out of a 12bolt strange rearend. We are trying to install longer studs for the new wheels we bought. We want to try and get this done asap. I was wondering if there was a website that showed you step-by-step- mike
Old Jun 8, 2007 | 03:41 PM
ws6transam's Avatar
Just guessing here, but I suspect you will find that the axle is retained by four bolts and an axle flange with bearing and O-ring underneath. Just unbolt the flange and give it a yank. That's how my Moser 12-bolt is set up.
Old Jun 9, 2007 | 06:44 AM
KGRESOCK's Avatar
Same on a Strange.
With a little creative grinding it can be done WITHOUT removing
the axles.
Old Jun 9, 2007 | 07:23 PM
Black Sunshine/ 00SS's Avatar
Originally Posted by KGRESOCK
Same on a Strange.
the axles.
Yes, if you remove the abs sensor, you can punch the studs out the hole if you spin the axle to line up with the hole. I prefer to just pull the axle out. You could probably get ahold of Scott & have him do it for you in a few hrs. I forgot his screen name. Maybe someone will chime in.
Old Jun 9, 2007 | 09:47 PM
KGRESOCK's Avatar
I didn't need to remove the ABS sensor.
Victor Lamb
Aug 26, 2017 02:52 PM
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
ddr698
Jan 9, 2015 10:05 AM
4586
Jan 3, 2015 07:22 PM
