Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Need rear sway bar endlinks asap!
Old Oct 22, 2003 | 10:23 PM
Rodrigues's Avatar
I tried putting the rear sway bar after ltlhomer and I installed the 9" rear and it hits the gigantic housing . I need longer rear sway bar links and I need them asap so if anyone has them ill take em
I also need a fuel rail because my shrader valve core got stuck! I need to use it to give fuel to my nitrous setup
Im still awaiting the driveshaft from DTS but it should be ready tommorow!
Old Oct 22, 2003 | 11:40 PM
Timberwolf's Avatar
Re: Need rear sway bar endlinks asap!
Just pull the schrader valve out with a pair of needle nose pliers. it's small and week and will fall apart with some tweaking.
For end links, just hit AZ. They are cheap and come in different lengths.
Old Oct 23, 2003 | 05:55 AM
dreamer1q's Avatar
Actually it is not longer links you need, it is a spaced style shackle/ubolt that you need. If you put a longer stab link on it you will either break the stab link, or bind the rear end.
Q
Old Oct 23, 2003 | 06:37 AM
IDOXLR8's Avatar
Does your rearend have the back brace welded on it? I know Spohn sells sway bar relocation brackets. You need to weld them to the housing.
Old Oct 23, 2003 | 07:52 AM
95 Z/28 LT1's Avatar
Super Moderator
They sell and stock energy suspension endlinks at most Autozones.
HarleyZ28
Oct 5, 2015 06:23 AM
96SilverRam
May 5, 2015 09:56 PM
PublicEnemy1
Apr 7, 2015 12:21 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
