Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
A little Help with A Code ??????
Old Jun 17, 2004 | 09:08 PM
Bill'sWS6's Avatar
I am looking at a car 2001 SS, supercharged. The car put down 450RWHP and has only 9,000 on the car, SPOTLESS.
The car does have a check engine light and is showing the following code:
check engine code - #420 - emissions leak.
What can this mean and how worried should I be. The code was reset using a scan tool but the code popped back up.
Thanks for any info you can give.
Bill
Old Jun 17, 2004 | 09:43 PM
Dave89IROC's Avatar
simplest possibilty(and most likely), gas cap not on tight(or bad)
worst case(unlikely), PCM
all it means is the PCM sees a leak in the evaporative emissions(gas fumes from tank and refueling)recovery system
Old Jun 18, 2004 | 12:07 AM
IrocSS85's Avatar
Im pretty positive the code 420 is a universal code about thecat. convertor effeciency. does the car have cats on it? does it have o2 sims? if it has cats on it and no o2 sims, you can borrow a pair (or just buy a pair) and plug them in to the back two 02 sensors and the code should go away.
bill, call my cell tomorrow midday and I'll check exactly what that code is for. and tell you what the poss.s are that can set that code. anything emissions related, can be programed out worst case scenario.
chris
313-655-2983
sounds like a fun car. tell us more details
Old Jun 18, 2004 | 07:21 AM
Kevyn's Avatar
420 ... lol maybe the car wants to smoke something.
Seriously tho... it looks like a cat issue.
http://www.obdii.com/codes.html
Old Jun 18, 2004 | 01:51 PM
Bill'sWS6's Avatar
The following is a link to the car. The owner is joking at the bottom of th ethread where he says 20K - the rims. I called and said I was on my way. He said he was joking because so many people were making low ball offers.
So, tell me what you think?
http://www.ls1tech.com/forums/showthread.php?t=173022
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
