Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
How busy will Milan be on Wed?
Old Apr 2, 2004 | 12:10 PM
v6maro's Avatar
Since it's opening day, how busy do you think they will be??
-Steve
Old Apr 2, 2004 | 12:35 PM
IROC5.7TPI's Avatar
Thats a pretty stupid question
Old Apr 2, 2004 | 02:20 PM
rod442's Avatar
Actually it depends on the weather.
If its raining or snowing it will be pretty slow .
Old Apr 2, 2004 | 05:19 PM
v6maro's Avatar
Obviously, but I have never been to an opening day at the track, are they usually packed with 1hr wait times weather permitting?
Old Apr 3, 2004 | 09:38 AM
rod442's Avatar
ok, enough kidding aside. usually if oyu can get there when they open, you can crank off 6-8+ runs in the 1st hour they are open. THEN after that you'll probably be lucky to make 3-4 more runs the rest of the day. Sometimes if you get there at 5ish, till 9 you might get only 3 runs in total. I have been there 4 hours and made 2 runs.
hope this helps. In closing, past performance is not a guarantee of future results. the weather may be great and it be dead there.
Old Apr 4, 2004 | 02:21 PM
CamaroBoy96Z28's Avatar
Yeah thats how it goes sometimes. Wednesdays are usually really busy. Fridays can be slow at times but then at 7:30 they start the street race and you can get a run or 2 in between rounds.
Old Apr 5, 2004 | 03:09 AM
Red5.7's Avatar
Well, last year (not opening day) on Wednesdays it generally wasn't too bad. But if you get there when they open you can click off a good amount of runs. Seems like the wait isn't bad, as long as people don't break. When people break, they are dumb and drive the whole length of the track for some reason
7/16/03 - 9 Passes
7/23/03 - 10 Passes
7/30/03 - 12 Passes
8/6/03 - 14 Passes
8/13/03 - 11 Passes (burnt a plug wire around 8 at night)
8/29/03 - 7 Passes (broke the rear early that night, within an hour and a half of getting there)
* All days were Wednesdays except the last one.
I made a decent amount of passes. The car ran the same hot or cold. I need more seat time and practice shifting.
Boss002
Jan 20, 2016 12:17 PM
95craz28
11
Sep 12, 2015 07:47 AM
POLOVETTE 94
Aug 21, 2015 07:11 PM
Aug 17, 2015 09:50 AM
jp2002ls1
Aug 30, 2002 08:18 PM
