Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Heads & Cam install?
Old Sep 17, 2002 | 02:02 PM
BlkDth's Avatar
How much would your expect to pay to have a heads and cam installed? How easy would it be to do yourself (with help from friends of course).
Thanx in advance...
Old Sep 17, 2002 | 02:09 PM
derty's Avatar
I did mine myself, it wasn't too bad. Just need to be patient and give yourself a day or two to do it (two or more would be preferrable). Depending on who you have install it would really depend on what they would charge. I know what I'd charge, but it'd be less than most with no accountability! Pictures of my install are on my website.
Old Sep 17, 2002 | 02:23 PM
BlkDth's Avatar
How much would you charge someone?
Old Sep 18, 2002 | 07:05 AM
derty's Avatar
I'd probably charge ~$400 for heads and cam or ~$300 for just a cam under the condition that the car would get on a dyno to get the A/F done right. I haven't checked what others are charging though, that's just a guess. If they did it cheaper (reputable shop) I'd go lower in some cases.
Old Sep 18, 2002 | 08:47 AM
BlkDth's Avatar
Are there any special tools needed to complete the job? Or that will make the job easier.
Old Sep 18, 2002 | 10:07 AM
derty's Avatar
Metric gear wrenches, fuel line tool, breaker bar, socket wrench and some metric sockets. A 250 lb-ft torque wrench will be needed for the pulley. That's about it. Depending on if your car is manual or automatic you will need something to lock the crank down so it doesn't spin when you try to break the bolt loose. It's just a knuckle breaking experience. Take your time and possibly look at getting a Helms manual.
Old Sep 18, 2002 | 01:08 PM
Black Sunshine/ 00SS's Avatar
I was going to say $500. But I dont have power tools. It is quite a job, but easier the more you do. Knowing the tricks helps.
We are going to do a cam install on Joe's car soon, so I get even more experience.
I think that you could do it, provided that you have patience, and dont force anything. Stop if you dont know something, and def have a helms manual. A friend helps when it comes time to pull the pulley. You wont need more than one person to help. Double check, tripple check, when putting back together. Good luck.
Old Sep 18, 2002 | 01:18 PM
2094you's Avatar
what year is the car ? i have some heads with comp
srings, crane 1.7 rr and a nos custom cam from
modern muscle car i put on my car and went 11.88 with a 125 shot .......... the whole pakage is youres for a 1,000$ greg at
detroit speed works has seen the car run
Old Sep 19, 2002 | 10:07 AM
BlkDth's Avatar
Thanks for all the info
birdblack
Dec 30, 2014 06:59 PM
Queens94z28
Nov 20, 2014 06:03 PM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
