Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
guru trans guy ( local )
Old May 3, 2007 | 07:24 PM
greezemonkey's Avatar
Got a problem, (aside from me knowing absolutely nothing about automatics) it`s a th350, this trans is a manual reverse w/ a pro tree brake...not all of a sudden but gradually it started to lock in reverse, what I mean is backing it off the trailer using the button to engage reverse loads the converter, it was little at first but now you need to just about floor it to make it move and it is not slipping, it is loading the converter. rolls in reverse in N fine or in "R" but not under power. all foward gears and the brake work properly and it has not lost any ET or MPH...any idea`s?
Old May 3, 2007 | 11:09 PM
AutoRoc's Avatar
check fluid and fluid level. I"m no guru
Old May 4, 2007 | 09:38 AM
blackplague's Avatar
I was reading this post on yellowbullet fourms
one thing to check is the trans brake solenoid. The solenoid looks like it has a big washer on the end that sticks out of the solenoid, push in on the big washer in then release it. Do this a few times. The solenoid should be smooth and free. If it isn't remove the solenoid and see if the solenoid is sticky or if the valve {and spring} in the case {behind the solenoid} are sticky. Other than that it sounds like a potential cross leak in the pump or maybe the valve body or stiffener plate bolts have loosened up causing a crossleak. If you have any questions, you can contact me at 586-255-3426. Mike.
Old May 5, 2007 | 07:01 PM
Thanks Mike! I think you may have replied at yellow bullet possibly, I`ll be checking it out this weekend and will let you know If I can find anything.
Old May 5, 2007 | 07:32 PM
IrocSS85's Avatar
damn greezemonkey, that cars look KILLER now. and its running the times to back it up too. cool car. one day......
Old May 6, 2007 | 06:38 AM
Hey Thanks Man I work 90 hrs a week on the P.O.S
Here`s a clip of it at norwalk last week
http://video.google.com/videoplay?do...20588795711310
Old May 6, 2007 | 08:22 AM
at anytime, just give me a call.
Old May 6, 2007 | 06:06 PM
IrocSS85's Avatar
cool.
Old May 7, 2007 | 05:30 AM
Cool Man, I got a bunch of the house chores knocked out this weekend and now I should be good to go on the car now! I appreciate the help!
Scott
Brake_L8
Jan 20, 2015 09:44 AM
cmdeshon
Dec 12, 2014 10:51 PM
mspennyhughes
Nov 28, 2014 03:22 PM
siguy
Nov 27, 2014 10:07 AM
Red97LT1
Aug 7, 2002 05:45 PM
