Front shock help...
Front shock help...
I put 1.25 inch lowering kit on my camaro i got to the last front strut and the bolt on the top of the shock was all rusted out. we tried gittin it off but it looks like its going to break. I went to pepboys to see how much a new shock was and it was $89.99
any one know where i can get one for cheeper or how i can get the nut off and not break it?
thanks, Dane
any one know where i can get one for cheeper or how i can get the nut off and not break it? thanks, Dane
yes she was drenched in pb blaster. I had to use a socket 2 sizes smaller on the nut because it was so rusted and falling apart....
by the way the car looks good even know it only has 3 lowering springs on and 1 reguar. I measured the distance from the wheel and the fender and their all the same even on the one with the stock spring.
Originally posted by Killerjello
do you mean the nut, or the actual threaded shaft on the shock?
If you mean the nut, just go to a bolt shop and theyll hook you up.
otherwise, if you want one, i may have front shocks with 70,000 miles on them (not sure if i threw them out) if you want one, pick them up and they are yours....
if you go buying a new one, make sure they have the same rates as your stock ones.
How many miles does your car have on it?
If you have quite a bit, i would see if SLP has any takeoffs left, and throw those on, they are close to new. thats what i threw on mine when they went bad.
Dane
Originally posted by mavricki18
Well the bold is rusted bad and the thred is too. when i try un screwing it the shaft spins. my car has 26,000 miles on it. I have nerer herd of the name on the shock ( De Carbon) ?
Dane
Dane
PITA! If you have access to a torch just blow that nut off. I got SLP take off Decarbons for $50 for all four shocks. Good Luck!
Originally posted by WHITE96SS
Yeah, the DeCarbons are stock equipment. I ended up using a sawzall on the shaft in between the spring coils
you can go to slponline.com and do a search for shocks or search part #'s 96309 (all four take-offs) or 96308 (rear take-offs) or 96307 (front take-offs) They still show them @ $25.00 a pair. Good luck
Boss002
May 20, 2015 12:55 PM
BLK1997Z28
May 1, 2015 12:23 PM
PublicEnemy1
Apr 7, 2015 12:21 PM
